88 E150 fuel system
Old Feb 27, 2018 | 08:54 PM
DJB's Avatar
DJB
Default 88 E150 fuel system
Good evening to all.
I need to change the fuel filter on my 88 E150 302 FI. How do I release the pressure before I open up the lines? Seems like a good idea!
Thanks in advance,
Dave
Old Feb 27, 2018 | 11:17 PM
Use Common Sense's Avatar
I always disconnect a lead going thru the fuel pump inertia switch. Or you can pull a fuel pump relay. Then run the vehicle till it dies. then remove the filler cap to eliminate any type of pressure in the tank. And the less fuel in the tank the better.
Old Feb 28, 2018 | 06:30 PM
I believe Use Common Sense gave you good advice.
What has worked for me was, the inertia switch is located at the top of the passenger side kick panel. With the engine idling , you can bang with your hand adjacent to the inertia switch and you will hear the little ball roll off the spot. After that the engine will falter and quit running due to no fuel. when you are done and ready to start the vehicle just push down on the inertia switch button and reset it and you are ready to go.
vman
Mar 7, 2013 07:00 PM
IrishE150Owner
Jul 9, 2012 07:02 AM
whateversclever
Mar 16, 2011 01:57 PM
whateversclever
Feb 18, 2011 10:12 AM
grumpydave
Jan 18, 2008 03:15 PM
