90 E250 Club Wagon ECM/PCM
Old Mar 10, 2022 | 06:09 PM
economacky's Avatar
Default 90 E250 Club Wagon ECM/PCM
Not sure if this is where I want to post this, but can anyone tell me where the Engine Control Module/Powertrain Control Module is located on a 90 E250 Econoline Club Wagon 5.8L XL? Any info is greatly appreciated.
Old Mar 10, 2022 | 06:54 PM
raski's Avatar
"Usually" it is located behind the drivers side lower kick panel. You might be able to see the big connector in the engine compartment bolted to the firewall where the kick panel would be on the other side. Double check the passenger side in case I am wrong.
If you have soldering skills, more than likely there are three electrolytic capacitors on the board that bulge out and leak. If you find that, replacing those likely would solve any problem with your ECM.
Old Mar 12, 2022 | 08:56 AM
If you didn't find it yet , it is located on the passenger side, either above or below the heater blower motor..
If you plan on removing it you will need a 10mm socket. If you remove the battery it is much easier to get to the plug and remove the bolt that holds it to the ECM.
The ECM comes out from the inside.
Old Mar 13, 2022 | 01:53 PM
economacky's Avatar
Default Found It1
I have located the PCM! Thanks to all who contributed in my success!
hi Jinx
Oct 2, 2017 09:57 PM
ford777
Feb 26, 2012 08:33 PM
Whynot987
Jul 6, 2008 12:25 AM
bikesandcars
Apr 26, 2007 12:22 AM
berbaby
Jan 13, 2007 08:28 PM
