91' E350 Need help identifying part
Old Mar 19, 2023 | 01:53 PM
Malonepat00's Avatar
Default 91' E350 Need help identifying part
1991 E350 superwagon 5.8L V8. Can anyone help my identify what part this is. It was a broken vacuum line on the other end of it that I want to replace. Thanks...
Old Mar 19, 2023 | 04:28 PM
Can you provide a little more info like , where it is located on the engine, and how many wires if any were connected to it if any?
If it has vacuum hoses on the upper part .it could be a thermal vacuum switch to control other valves that are vacuum controlled, which could be most likely emission controls. Can you tell us where the hoses go?
We should be able to come up with the correct answer once we have some idea of what it controls..
Because of the age we might have a little problem finding one , but we don't know until we try.
May be able to come up with a vacuum diagram. They were usually under the hood in the engine compartment.
Old Mar 19, 2023 | 09:55 PM
Its the heater/water control valve.
It controls heated coolant flow into the heater core. The vacuum lines like to rot and flake away..
Old Mar 21, 2023 | 06:09 AM
Great 👍 thanks for the info!!
Clockmanchris
May 20, 2022 01:12 PM
Stephanie Marie Diaz-Gonzalez
Oct 8, 2017 02:13 PM
baconater357
Feb 9, 2017 03:11 PM
Howard57
Aug 30, 2013 04:57 AM
dgoodall
Jun 3, 2010 09:58 AM
