94 e150 steering gear box replacement
Old Nov 13, 2011 | 07:05 PM
ac917x's Avatar
Default 94 e150 steering gear box replacement
i have a 94 e150 with the 4.9 inline 6. how hard is it to replace the steering gear box? i replaced the pump and the steering still hard. thanks
Old Nov 14, 2011 | 03:55 AM
Before you get involved in changing the steering box try to determine that you don't have a possible hose problem. It's not a good feeling after you change the box and still have the same problem.
If you decide to change the box anyway, be sure to lock the steering wheel in the center position to prevent ruining the clockspring under the steering wheel since it is an important part of the airbag restraint system.
Old Nov 14, 2011 | 12:03 PM
ac917x's Avatar
how do i tell if its a hose problem? i dont see any leaks. thanks for the fast reply
Old Nov 14, 2011 | 05:26 PM
A leaking hose isn't the problem . A restricted or blocked hose (pressure side) could be the problem.
Also,,,,, I wish you could tell us you bought your replacement pump from Ford because some aftermarket pumps leave a lot to be desired and just plain don't always work !
Make sure you get all the air out of the system. That may require turning the wheels back and forth many times with the engine running to purge the air out let it set a while for the air to come up to the top and doing it over again.
Old Nov 19, 2011 | 10:03 PM
ac917x's Avatar
also when i refilled to try out the pump it took less than a quart.
Old Nov 20, 2011 | 01:41 PM
Try loosening the pressure hose at the steering box and see if you get any fluid coming out when turning the steering wheel with the motor running.
Old Dec 18, 2011 | 12:02 AM
ac917x's Avatar
thanks for the replies it was the gear box.
BaaRamEwe
Jan 29, 2020 08:10 PM
larryzzzz
Sep 8, 2014 11:26 AM
itismej
Aug 10, 2014 09:30 PM
mikeregister
Apr 19, 2011 08:05 PM
projectprerunner
Dec 27, 2007 04:06 PM
