95 E350 stalls
Old May 8, 2008 | 04:23 PM
RedHat's Avatar
Default 95 E350 stalls
Hey anyone out there have any insight about why my E350 / 5.8 is stalling?
I replaced the idle air control valve, still stalls. When i come to a stop, and more frequently when i shift to reverse:
Update, still stalls as above however I have a question, would a malfunctioning speed sensor contribute to a stall?
Information I have gathered so far indicates it is the throttle body needs cleaning which I am planning, but I'm sure its a sensor.
A couple days ago I made a short left to a stop, and after the stop there was a bump which was the posi engageing I think, another thing that happens is when I stop after a period of accelleration (freeway) and I attempt to move forward again it behaves as it is neutral until the rear end engages and care must be taken to avoid slamming it. I get the sense the ECM thinks the vehicle is moving when it is stopped.
Old Dec 17, 2008 | 12:00 AM
goinstrong's Avatar
Default RE: 95 E350 stalls
Speed is often checked at the transmission - not at the axle - so a computer can 'F' it up. Posi rears wear out too. Maybe have the axle internals checked out - especially if you tow a lot or haul heavy loads. How many miles are on it?
Old Dec 17, 2008 | 12:01 AM
goinstrong's Avatar
Slamming engagement can be the transmission too. And don't forget to keep an eye on your air filter.
info@shingleexpress.com
Mar 22, 2014 05:10 PM
CoreyTrevor
Oct 27, 2009 12:54 PM
new driver
Apr 18, 2005 01:16 PM
slimjim
Apr 4, 2005 06:01 PM
Loum12
Mar 28, 2005 11:43 PM
