AC Heat Blower
Old Dec 12, 2010 | 03:42 PM
rojoyce's Avatar
Default AC Heat Blower
2001 ford e 250.. replaced fuse, relay, resistor and blower motor...I dont get air flow from vents.. heat or ac..... I have seen multiple threads on this but not an answer that i can use.. If anyone can help it would be awesome.
Old Dec 13, 2010 | 06:25 PM
To clarify, is the blower motor running at any time? If not, then check the plug behind the blower switch assy . If it is melted, there is your problem. The heat would cause a bad connection between the supply and the rest of the switch positions. Before going any further did I understand your problem correctly?
Old Dec 14, 2010 | 07:13 AM
rojoyce's Avatar
Hanky, thanks for your response.. yes it is running. i checked it last night.. I am thinking it is the airflow door? I am getting minimal air flow only through 1 vent, which i think is residual from the engine.. do you know if there is a switch or sensor for the door?
Old Dec 14, 2010 | 02:59 PM
I wish I could be of more help on the exact operation of the doors. Unless someone with more definite knowledge of them comes forth, you might if possible remove the glove box and look to see which doors are responding to which positions of the function switch.
You just might see something moving as you change positions on the switch and no change in air flow. It could give you a clue to where the problem lies.
Old Dec 15, 2010 | 06:44 PM
rojoyce's Avatar
Yes, I plan on ripping it all apart this weekend and try to narrow it down.. Thanks for your input. I will post anything if I find the problem.. or a solution.
ricknags
Apr 5, 2019 02:39 PM
Use Common Sense
Jun 25, 2016 01:30 PM
lucas
Jul 4, 2011 07:19 PM
ddbaran
Nov 29, 2006 10:33 PM
Deam
Aug 1, 2004 06:20 PM
