no blower, no heat or ac
Old Jun 21, 2011 | 12:59 PM
lucas's Avatar
Default no blower, no heat or ac
2001 e-150, blower does not work at any speed, checked the fuses, just replaced the switch panel, still nothin, it just quit while I was driving one day, did come back on briefly the other day, but still nothin. Should I just try and replace the blower motor? thanks, Dan
Old Jul 3, 2011 | 11:47 AM
mary gladd's Avatar
Try looking at the wires going to the blower under the hood. My Van was doing that same thing. The wires i found that caused the problem were behind the Battery up against the firewall in the corner behind the Air Conditioner piping. try wiggling them after u have turned on the heater/air control.
Old Jul 4, 2011 | 07:19 PM
There should be two wires coming out of the blower motor itself a black wire and an orange wire. Unplug those wires and power them directly with a ground to the black wire and just touch a jumper wire from the positive post of the battery to the orange wire. The motor should run briefly , if it does that confirms the blower motor is ok. Depending on what result you post will determine what steps you might do next. Will wait to hear from you.
ricknags
Apr 5, 2019 02:39 PM
Use Common Sense
Jun 25, 2016 01:30 PM
rojoyce
Dec 15, 2010 06:44 PM
ddbaran
Nov 29, 2006 10:33 PM
Deam
Aug 1, 2004 06:20 PM
