Bad torque converter or trans?
Old Jun 16, 2023 | 11:00 PM
bradhol357's Avatar
Default Bad torque converter or trans?
So i replaced the head gaskets on my 06 e250 and when i pulled the transmission off i wasnt aware that the torque converter must be attatched to the trans at all times, so i destroyed the front pump, so i dropped the trans replaced the front pump and it ran great all of 10 minutes before trans started overheating and wouldnt move, so i once again dropped the trans replaced the front pump because i thought maybe i did it wrong, and it still wont move pls help i really need to sell this thing asap.
Old Jun 17, 2023 | 10:42 AM
Certain solenoids need to be activated for the pump pressure to go where it is needed.
You `would do much better if you had a capable scan tool to tell you if certain info is going where it is needed..
Old Jun 17, 2023 | 02:43 PM
bradhol357's Avatar
well i dont have acess to one, i just got a new torque converter and i think im going to do that because i think it might have got destroyed when I installed it wrong the first time. Also there was a lot of black powder when i popped of the trans oil pan
Old Jun 18, 2023 | 08:42 AM
If you never removed the trans pan before, paste in the bottom of the pan is somewhat normal due to thrust washer and clutch disc wear.Should be cleaned out before assembly . The torque converter has 2 tangs that must engage with the slots in the pump drive gear on assembly. When it does you will feel/see the torque converter go all the way in and rotate freely. If you do drop the pan , you might consider purchasing a filter kit for that exact trans. They come with a filter , seal and pan gasket.
No adhesive is to be used to hold the gasket to the pan. Cleanliness is essential !
Old Jun 18, 2023 | 01:17 PM
bradhol357's Avatar
I did get a new filter and I am aware of the 2 tangs now so I’m gonna install this new torque converter and hope for the best
Old Jun 20, 2023 | 07:01 PM
bradhol357's Avatar
ok so i installed the the trans again with the torque converter i got from the junkyard and purged all the lines of air so obviously the front pump still works, but now it wont move unless you gun it to 3000 rpms and then it only crawls so im assuming the torque converter is bad?
Old Jun 21, 2023 | 06:27 AM
That pump must develop good pressure and unless you get some pressure readings , you could be pulling the trans AGAIN.
laslomustang65
Jun 20, 2022 06:04 PM
lombardothomas@hotmail.fr
Apr 26, 2021 07:10 AM
75yfl6
Sep 28, 2016 07:28 PM
94crownvicon22s
Dec 29, 2008 12:05 AM
STEVE1103
Mar 3, 2005 11:19 AM
