Brake pedal doesn't engage until half way.
Old Jul 1, 2023 | 01:39 AM
ThisGuy's Avatar
Default Brake pedal doesn't engage until half way.
Hi all. I have a 1998 E-150 4.6L 2V that I'm having an issue with. The brake pedal is soft and doesn't bite until its a little more than half way pressed. Once it hits that sweet spot the pedal gets hard and brakes well. With the van off, the pedal gets rock hard with 3-4 pumps so im assuming the master cylinder is ok. I've replaced both front calipers, rotors, and pads. Bled all 4 corners of the car multiple times and added new fluid. The brake fluid is always at the same spot so no leaks either. Any ideas?
Simon 66
Sep 29, 2023 03:23 AM
engeladus
May 21, 2023 06:56 PM
Steve Knotts
Sep 16, 2019 03:41 PM
Moondoggie
Nov 27, 2015 04:27 PM
Redfridge
Oct 22, 2013 03:46 PM
