Change Coolant color
Old May 30, 2023 | 08:40 PM
ligren's Avatar
Default Change Coolant color
Hi community. I have 1999 Econoline E-150 with 5.4 Triton engine. Right now car uses Green coolant.
https://parts.ford.com/content/dam/f...sage_Chart.pdf
According to the label right now coolant should be : E2FZ-19549-AA (or equivalent to Ford coolant Spec# ESE-M97B44-A).
I do full coolant flash.
Can I change coolant to Yellow after full coolant flash and cleaning the system
for example to this one for example to this one
Old May 31, 2023 | 10:33 AM
The older Green coolant did have some problems contributing to a condition called solder bloom where it managed to corrode some parts.
I have been using the yellow , long life coolant in all equipment and have not developed any problems.Must be mixed in the proportions as directed.
Old May 31, 2023 | 11:03 AM
ligren's Avatar
Thumbs up
Thanks!
So, your advice to switch from factory recommended green to yellow after full flush, right?
Old May 31, 2023 | 02:22 PM
The Long Life coolant possibly was not available at the time the vehicle was manufactured.
You can use either coolant , just mix it with water as specified, and if the system is fairly clean, you should be OK. Just don't forget to replenish some of the older coolant as it losses some of it's corrosion protective features as it ages in use.
over40
Jan 12, 2022 06:11 AM
lowie182
Mar 6, 2019 11:06 PM
paul64
Aug 1, 2012 09:55 PM
jjcast13
Jun 28, 2009 07:56 PM
davidp
Jan 9, 2006 05:07 PM
