Climate control switch
Old Aug 17, 2017 | 07:56 PM
Jeffintampa's Avatar
Default Climate control switch
The switch for the air max air normal vent floor defrost etc isn't running my blower right
The fan wont be on when I start it I have to cycle it to floor vent max air and it comes on sometimes. I seem to have to do this quite often now
wonder what the fix is
Old Aug 19, 2017 | 12:37 PM
Well I changed my blower resistor thing that was beside the fan did not fix seems to have gotten worse cant seem to get the fan to come on in any setting
feel the blend doors opening when I change around so system seems to have power
Old Aug 19, 2017 | 02:14 PM
You might consider removing the blower motor itself and see if it isn't locked or difficult to rotate. It should spin with very little effort. If not replace the blower motor.
Old Aug 19, 2017 | 02:18 PM
thanks hanky,
It would come on every now and then usually on floor. then I could move it to air and it would stay on. changed the resistor and nothing works now wont even blow at all grrr hate **** like this
Old Aug 19, 2017 | 02:41 PM
checked the fuse its fine
Old Aug 23, 2017 | 03:31 PM
Default fixed
Well as we are taking a trip soon took it to the local shop for oil change tire rotation trip inspection. and fix fan
They fixed said it was a blower relay 10.00
mawwam
May 18, 2009 05:05 AM
jlgshgsho
Feb 18, 2006 04:29 PM
93scortfury
Dec 21, 2005 01:33 AM
2BDiesel
Sep 8, 2005 11:47 PM
getchamowinon
Jun 20, 2005 07:31 AM
