dome lights
Old Dec 12, 2011 | 04:48 PM
r.sawyer33's Avatar
Default dome lights
i have a 2002 i do not have dome lights when i open the doors or turn the switch i can touch the light and it will come on they did work a while ago i have checked the fuses all r good i have replaced the head light switch and same i have been banging my head over this can some one point me the right way thanks for any help i am new to this site
Old Dec 12, 2011 | 05:13 PM
bluewind's Avatar
Did you replace the bulb itself? Is there corrosion on the contacts?
Old Dec 13, 2011 | 08:14 AM
r.sawyer33's Avatar
no the light works it just will not come on when i open the door or turn the head light switch
Old Dec 13, 2011 | 02:25 PM
I would suspect a communication problem with the BCM and the interior light system.
Old Dec 14, 2011 | 09:04 AM
r.sawyer33's Avatar
ok so what can i do what is the bcm can i buy one from the auto parts store
Old Dec 14, 2011 | 09:42 AM
The BCM is the body control module, in Ford language , the GEM, generic electronic module. The module is a dealer item, not cheap, but you should have it checked out before spending any money because it could also be a bad connection between the systems that communicate with one another , power to or ground connection.
Old Dec 15, 2011 | 06:14 AM
r.sawyer33's Avatar
ok thanks were would be on the truck
cu101man
Feb 1, 2010 11:35 AM
pats99ranger
Feb 17, 2009 12:25 PM
cj3a
May 31, 2008 04:48 PM
kkohle
Apr 23, 2008 11:38 PM
kkohle
Apr 23, 2008 06:10 PM
