Easy question
Old Mar 2, 2018 | 04:51 PM
jlawson435's Avatar
Default Easy question
for somebody smart (not me) had a check engine light come on. Pulled in to Auto Zone. Said it was Mass Air Flow Sensor ok easy. Went home got out my QD Electronic Cleaner took it all apart and sprayed and cleaned real good. Two days later light comes on again back to a different Auto Zone read computer said Mass Air Flow Sensor that is the only code coming up and was cleared last time came home took apart again looked at it close everything looks good cleaned even better put back in guess what 1 day later light back on. you got it same thing is the Mass Air Flow Sensor just bad and needs to be replaced
Old Mar 2, 2018 | 06:28 PM
We all look for an easy one, but I'm not sure if this is it !
Before just going to get another MAF sensor what if you told us the exact code for starters?
Then , a good percentage of the time checks of power and ground need to be verified and finally the signal from the sensor needs to make sense (be rational).
Then verification of the signal getting to the PCM.
So what looks like a piece of cake job can get a little involved, but that is the better way to go.
I guess if you are brave and are willing to give it a shot, you might replace the MAF sensor without doing the checks.
Old Apr 21, 2018 | 10:39 AM
jlawson435's Avatar
ok when then was first done it pulled codes P0171 and P0174 they said PCV valve ok replaced that reset computer. ran great yesterday out driving it check engine light come on again turn into Autozone and they pull same codes P0171 and P0174 could this be a vacuum leak someplace or what
carid
Jun 23, 2015 06:23 AM
Christian0001
Sep 11, 2012 07:13 PM
Tobotech
Mar 20, 2012 01:51 AM
raccam1976
Jun 15, 2008 07:33 PM
shel67
Sep 29, 2006 08:19 PM
