EGR Valve '96 e250
Old Apr 29, 2011 | 06:34 AM
McStein's Avatar
Default EGR Valve '96 e250
Any tips on pulling that out? I can't get anything to the bolt on the exhaust manifold. I need to clean it out. I think the carbon build up is making my engine studder and die when coasting to a stop.
Its a v8 5.8L automatic.
These are the codes I got:
o2 sensor bank 1 sensor 1
pw sensor bank 2 sensor 2
EGR flow insufficient
DPFE monitor low voltage
Old Apr 29, 2011 | 10:31 AM
Usually when EGR flow is insufficient the vehicle runs better. I think you may have a different problem. Will have to check out those codes. Could you post the #s?
Old Apr 29, 2011 | 09:51 PM
McStein's Avatar
They didn't give me code numbers at advance auto. They gave me that list from their reader. I did replace the dpfe and saw that the ref line is completly clogged. I think that the computer thinks that the engine can handle more exhaust which is leaning out my mixture making my engine shudder and die as we coast to a stop. I tried scraping out what I could and sraying carb cleaner into the vacume line but it hasn't helped. I need to get to the rest of the egr setup but I can't get a wrench to the big pipe that goes into the exhaust manifold.
Old Apr 30, 2011 | 04:33 AM
What I believe is happening is, the EGR Valve is stuck open because of accumulated carbon. Sometimes a temporary solution of tapping on the valve will dislodge the carbon and allow the valve to close. That may give you some time to obtain the tools you need to clean it out or replace it if necessary.
Old Apr 30, 2011 | 08:32 AM
McStein's Avatar
thanx. I'll give that a shot and see if that helps.
Old May 3, 2011 | 07:56 AM
McStein's Avatar
Tapping it works for about a day or 2. Thanks for the help. It'll get me through till I have some time to break into it again.
Old Feb 3, 2012 | 08:01 PM
epm103's Avatar
I went through all the fixes for almost year to figure out the same problems. Garages had no clue why its not fixed. I did all work myself after that and came across a TSB and had to get the computer updated. Only ford did it and its been 4 years no problems. @ $80 to be hooked to the computer At Ford
fordwoman99
Mar 3, 2013 05:24 PM
dee004
Apr 20, 2010 10:16 PM
crimey617
Aug 15, 2007 01:46 PM
localtoys73
Oct 20, 2005 11:50 PM
DAbbe1013
Sep 11, 2005 12:19 AM
