fast idle problem 88 ford e-150
Old Feb 18, 2007 | 02:08 AM
shoes's Avatar
Default fast idle problem 88 ford e-150
Three years ago I replaced the throttle position sensor on my van to solve an idle problem. Now about 2 months ago the idle started to run very fast. It does not surge or vary in any way just runs fast. I did get a check engine light on yesterday so there is a code stored even though it went out but where is the place to plug into to get the code? Please help if you can!!!!![&o]
Old Mar 2, 2007 | 03:20 PM
shoes's Avatar
Default RE: fast idle problem 88 ford e-150
Follow up to my problem. After taking it to Auto Zone and getting the codes I still was not able to fix it so I took it to a mechanic. 360 dollars later its running fine. The problem was mostly a bad gasket under the throttle body. They also replaced the tps which I replaced myself about 4 years ago. Also they replaced the temperature sensor which seems to have helped my temperature guage read a little cooler. I cannot say all this was the problem but its fixed and thats what I care about.
Old Mar 4, 2007 | 05:15 PM
boflaade's Avatar
That's good news and sounds like the money was well spent. Thank's for the update.
arkansas-bigfoot
Jul 31, 2014 01:49 PM
dsquinn
Dec 15, 2011 03:20 PM
dsquinn
May 18, 2010 03:12 PM
moford
Dec 3, 2005 01:45 PM
bingermann
Nov 11, 2005 01:47 PM
