forums
Old Oct 24, 2010 | 02:13 PM
sonicpops's Avatar
Default forums
Hi,
I see a lot of posts, a lot of views, no reply's?...
Is there another Ford Forum group out there that have people in it with mechanical skills and that reply to 'need help' questions?
Thanks, MK
Old Oct 24, 2010 | 03:55 PM
No guarantees , but go ahead , ask your question!
Old Oct 24, 2010 | 06:10 PM
sonicpops's Avatar
Default 1998 E350 Powerstoke Clubwagon brake problem
Hi Hank, thanks for the reply.
I previously posted this yesterday.. Here it is again.
Hi, newbie here.
Hope someone can help... In the AM, when I first drive off, I touch the brakes to stop and the front left wheel chirps and skids for 6 inches. This continues for the next 10 braking moments. I have replaced the front pads and the left side is worn far more than the right. What could be leading to the problem? What should I start checking first?
Thanks, MikeK
E350 Clubwagon Powerstroke 7.3 1998
Old Oct 25, 2010 | 04:08 AM
Let's think this out a little. Either the left front is doing all the work or the right front isn't doing its share.
Are the caliper pins clean and lubed to assure free movement, BOTH SIDES, ?
I would make one brake application as you state when first starting out and then remove the L/F wheel to be sure the caliper is not dragging. Possibly the brake hose has a restriction in it preventing the caliper from releasing. Also , make sure the right front caliper is free to do it's job. Did you remove the accumulated rust between the caliper and the wheel spindle so the caliper doesn't jam while trying to move? Take a file and clean the rust from the surfaces so the caliper has some ply to move.
Let me know what you find.
Old Nov 20, 2010 | 07:48 PM
hookuspookus's Avatar
Default yep
Hi, newbie here.
Thanks, MikeK
yes hanky was right , if your rim is hot also this is a sign of lock up if your going to change the caliper change the brake hose as well
LTHL PSI
D'Agostino Racing
Aug 17, 2006 09:42 PM
jddaero
Mar 6, 2006 10:37 AM
IownAford
Oct 21, 2005 05:18 PM
stang99x
Sep 13, 2005 11:46 PM
stang99x
Sep 13, 2005 11:44 PM
