fuel update
Old Aug 7, 2012 | 10:42 AM
two bit okie's Avatar
Default fuel update
I am the guy with the 1990 e 150 club van with the bad fuel tanks.
Ok here is the update. after being towed home 5 times, I finally got te stuff to fix the main fuel tank. new pump, whole new assembly. biggest problem wilth the rear tank was the rubber hose from the actual pump the fuel assembly was GONE. not cut, not cracked, none of the easy stuff, it was not even there, It had been but was not now. So cleaned the tank, put in a new assembly, and it runs gang busters.
since I have heath problems called medical and drug bills, and am in the donut hole, the middle tank will have to wait till January.
I will update when all is finished. and thanks for everyones input
Old Aug 7, 2012 | 08:27 PM
Glad you were able to solve the vehicle's problem. Wish you well and don't worry nobody else will do that job on the middle tank on you !
RealFnCool
Oct 25, 2007 06:44 PM
mach
Jul 16, 2007 08:28 PM
dannyf150
Feb 25, 2007 03:10 AM
fu3x
Mar 23, 2006 09:39 PM
pterns
Nov 14, 2005 11:57 AM
