Heat in the rear but no heat in the front
Old Sep 22, 2017 | 08:35 PM
tattooed_drew's Avatar
Question Heat in the rear but no heat in the front
I have a 98 e150 club wagon with heat issues. I have heat going to the back of the cabin but no heat to the front. I have replaced the heater core, thermostat, and the heater by pass valve with no results. I also inspected the heater flap door and actuator and they seem to be working properly. I am at a loss anyone have any suggestions or answers, it would be really appreciated.
Old Sep 23, 2017 | 07:34 AM
After running the engine about 5-10 minutes feel the hoses under the hood going to the front heater core and see if both are warm/hot. They should be almost the same temp.
If not , there is a good chance the heater core is full of trapped air. You might need a special tool to release to upper hose at the heater core ,with the engine running,and pull the hose back just enough to let the air out because after that coolant will come rushing out. See if that doesn't correct the problem.
Old Nov 9, 2017 | 08:00 PM
Yes I checked to make sure the hoses and they were pretty warm. I also tried by passing my rear heater core to see if that would make any difference but nope it didn't. I also replaced the hot and cold switch that also did not work. Not sure where to go from here.
Old Apr 6, 2020 | 10:59 AM
Pappys2002's Avatar
I'm having the same problem with my '99 Windstar. Did you ever find the problem?
The Haynes manual suggests it might be a blocked heater core or hose. Recommendation is to unhook the hoses and back flush the core. I may try that today. There is one fuse that controls the heater blend door but it has other things running off it so I doubt that is going to be the problem. Still worth checking out.
Christian Butter Poulin
Nov 9, 2018 02:17 PM
paulv718
Jan 18, 2017 09:23 PM
1999EBEXP
Oct 24, 2011 10:58 AM
daviddc114
May 25, 2008 07:38 AM
gigs16
Mar 26, 2007 01:53 PM
