Help Me Decipher Vacuum
Old Mar 9, 2011 | 09:10 PM
raccer's Avatar
Default Help Me Decipher Vacuum
1988 E350 1Ton
5.8L (Above 8500 GVR Engine)
Auto, No A/C
So as simple as this diagram appears I need help understanding which components are what. The abbreviations may make sense to a Ford tech, but I'm in the dark.
More specifically:
-> What are the (2) VRESER modules in the lower left hand corner?
-> What is the EVR module middle bottom?
-> What are the SOL V modules lower right?
-> What is the CPRV module between the throttle body and carbon canister?
Thanks in advance for any input!
Last edited by raccer; Mar 9, 2011 at 10:24 PM. Reason: hit enter on accident before I was done posting!
Old Mar 9, 2011 | 10:11 PM
raccer's Avatar
More questions:
-> Why is the throttle body/CPRV/Carbon Canister circuit a dotted line?
-> Why on that dotted line, are some junctions open circles while others are filled circles?
Old Mar 10, 2011 | 01:28 AM
Vreser = Vacuum Reservoir (Sometimes a Tomato Juice Can)
EVR =EGR Vacuum Regulator Valve
Sol V = Solenoid valve (controlled by the ECA)
TAB =Thermactor (air pump) Air By Pass Valve
TAD = Thermactor Air Divert
CPRV = Canister Purge Regulator Valve (Controls when canister purge takes place)
DIV = Diverter Valve
Air By Pass = Air By Pass Valve
Sometimes the dotted lines can mean ,If equippedm or part of a system
Other times there isn't enough room to show the tubing.
Old Mar 10, 2011 | 11:20 AM
raccer's Avatar
hanky!
You're awesome! Thank you. I found my Canister Purge Regulator Valve hanging by it's wire harness dangling inside the engine compartment.
I need to replace all the soft vacuum lines & hopefully be able to smog this behemoth.
Thanks Again!
rj ford fan
Dec 13, 2010 06:30 PM
brolajit
Nov 1, 2008 04:10 PM
jhcope
Oct 8, 2008 09:41 PM
