Memory steering after replacing ball joints.
Old Jul 23, 2025 | 07:37 PM
ThisGuy's Avatar
Default Memory steering after replacing ball joints.
I replaced all 4 ball joints on my 98 e150 about a month ago. Immediately upon reassembly and first drive, the steering would continue to hold direction and not self center as it should. I replaced them with moog problem solver and made sure to follow the proper torque sequence and specs. I greased them up, got an alignment, and drove for approx 2k miles and the problem never went away. I thought maybe I received bad joints so I replaced all 4 again and nothing changed. Today, I replaced my steering gearbox with a redhead unit and the memory steer became even worse and is affecting stability on the highway from constant input correction. I'm at a loss for what to do, but im 100% sure it has something to do with the ball joints. Anyone have anything similar happen?
Old Jul 24, 2025 | 01:32 PM
If you think about this. which way did you have the wheels pointing when you tightened the ball joints ? They are supposed to be in the straight ahead position when tightening, try it !
Old Jul 24, 2025 | 07:04 PM
ThisGuy's Avatar
I actually don't remember if they were straight ahead when I torqued them. I'll take it apart tomorrow and report back!
Old Jul 25, 2025 | 12:23 PM
ThisGuy's Avatar
Resetting and retorque the knuckle didn't fix it but I did notice that when I tighten the castle nut for the bottom ball joint, even just a little, the knuckle stiffens up a bit when moving side to side. It is still able to be moved with one hand but it doesn't flop around smoothly and there is a little resistance. This happens on both sides. I tried whacking everywhere to seat it more and lubed everything up really nice but nothing worked. What is causing this?
Old Jul 25, 2025 | 05:27 PM
Did you clean the tapers where the stems fit ?
Old Jul 25, 2025 | 05:49 PM
ThisGuy's Avatar
I sanded and cleaned the tapers for the lower ball joints and I purchased new camber sleeves for the uppers before the alignment. From what I've been researching, it seems moog has an issue with some of their joints being very stiff. I just ordered a set of mevotech and plan on replacing the moog. Hopefully third time is the charm.
Old Jul 26, 2025 | 08:15 AM
dpboone's Avatar
Make sure that use a torque wrench on all. You can find the specs online.
Old Aug 2, 2025 | 04:28 PM
ThisGuy's Avatar
I've put in 3 sets of ball joints now and memory steer is still there. I've replaced everything in the front end except suspension springs and intermediate steering shaft. Everything torqued to spec. Alignment done with 4.5 caster. I guess it's time to bring it into the shop.
Old Aug 3, 2025 | 06:32 AM
You may wind up replacing the struts OR the bearing plates for the struts..
Bigd74
Aug 12, 2019 02:53 PM
paulv718
Dec 21, 2016 07:54 PM
warriorkin
Jun 26, 2014 04:10 PM
cuttman
Nov 2, 2012 07:00 PM
crs5357
Jun 16, 2005 11:21 AM
