My 2013 E150 will not start after heavy rain.
Old Jul 29, 2024 | 02:25 PM
Commanderhurtz's Avatar
Default My 2013 E150 will not start after heavy rain.
Hey there! I have a 2013 Ford E150 and the engine will not come on after it has rained. We have checked Fuses/Battery/Fuel and they're all good, the starter is working when I turn the key. Any idea what could be the problem?
Old Jul 29, 2024 | 02:27 PM
I forgot to mention that my Van is a 4.6L.
I also posted this same topic on Reddit, and I managed to put a video/example there. https://www.reddit.com/r/carproblems...heavy_raining/
Old Jul 29, 2024 | 03:38 PM
And another update, I pulled off the PCM and ECM cables, the connectors had water in them, the middle one having the most, water dripped out.
Old Jul 30, 2024 | 07:03 AM
You are on the right path. Just make sure the plugs are clean and dry.
You might check the weather stripping where the hood contacts it when the hood is closed. If it does not make good contact to make an effective seal, the water will get in and cause problems among which is corrosion and possible alternate paths for power to take.
Old Aug 1, 2024 | 02:16 PM
I took out the ECM and connectors to try and let it dry, no fire. So far I've had no luck so I might have to get it to a mechanic.
Old Aug 1, 2024 | 03:40 PM
Can you check if you have fuel and spark available at the spark plugs?
After attempting to start the engine, remove one or two spark plugs. Are they wet with gasoline or dry?
Old Aug 4, 2024 | 06:21 PM
Update! Me and some family members took out a ignition coil and spark plug, didn't see any water on it or didn't smell any gasoline on it.
Cmax lover
Sep 20, 2022 03:53 PM
DLESTER56
Mar 11, 2022 03:20 PM
mikey p
Jan 6, 2015 09:45 AM
jersey girl
Apr 8, 2013 01:00 AM
trev0006
Jun 6, 2012 01:20 PM
