Plug Wires Heeelllppp Plzz!!
Old Mar 2, 2018 | 09:13 PM
Bronny25's Avatar
Default Plug Wires Heeelllppp Plzz!!
Ok I have a 97 e150 with 167000 Miles. I just replaced my plugs and new plug wires do to a misfire I was having. The plug wires keep popping off the plug after a few miles of driving I will have to pull over pop the hood and push the plug boot back Down..only two boots doing it.
The plugs are tight and the boots do pop when I push down. I will be good for a bit then the van will start missing.
why would they do pooping off???
thanks!!
Old Mar 3, 2018 | 10:42 AM
Just out of curiosity , which two plug wires are they?
Plug Wires or coil on plug set up ?
Old Mar 3, 2018 | 02:10 PM
Bronny25's Avatar
3 and 7
Old Mar 3, 2018 | 02:32 PM
What about the "wires" , Coil on plug or wires?
Old Mar 3, 2018 | 07:52 PM
Bronny25's Avatar
It’s 3 and 7
Old Mar 3, 2018 | 09:05 PM
I rec'd your reply re cyls, but I need to know if your vehicle has coil on plug (COP) or spark plug secondary wires. Anything is possible, but the info I checked suggested that the vehicle has cop system. Which does your vehicle have?
Old Mar 3, 2018 | 09:19 PM
I found your reply stating COP under another post.
I need some help from you here, the coils are held onto the spark plugs by a 8mm bolt.
If this is what your vehicle has are you saying the coil is actually getting blown off the plug?
Or,,,,,,,,,,,do you mean the 2 wire plug that goes onto the coil is coming off? If that is the case, the locking tab that holds the 2 wire plug on the coil is broken and when we have that problem one temporary solution is to zip tie the 2 wire plug to the coil .
Where do we stand ?
Old Mar 3, 2018 | 10:08 PM
Bronny25's Avatar
The long black boot is loose when I feel under the hood as in the silver clamp inside the boot which “snaps” onto the top of the spark plug is no staying snapped. The plug wires them self are in good shape. It’s the actual cop keeps popping off the top of the plug. They are literally two days old and when I installed them I push the boot until I here snap and that short give.
Old Mar 4, 2018 | 04:13 AM
Inside that coil boot is a spring that is supposed to clamp around the top of the spark plug. It sounds like the spring has either been burned off or the heat has expanded the spring coils and they are no longer holding.The coil holdown bolt is there to hold the coil from coming off and to provide an electrical connection . Are the bolts missing ?
NYRPM
Mar 5, 2018 12:33 AM
500xcpol
Jul 12, 2007 06:32 PM
FordCountry180
Apr 4, 2007 05:02 PM
MHartley
Jan 20, 2007 11:49 PM
jerryford2001
Jul 22, 2006 11:17 AM
