Rotor help
Old Dec 2, 2018 | 05:52 PM
Pnwmama's Avatar
Default Rotor help
Hi,
I'm currently working on changing the cap and rotor on my 96 E350 460, and in all the videos I watched the rotor comes right off but mine is stuck! How do I get it off without damaging anything else ? TIA!!
Old Dec 3, 2018 | 01:34 AM
Use Common Sense's Avatar
Check to see if you have a TORX head bolt holding it in place or washer clips over the studs. If not, sometimes a little heat around the rotor at the hub area will break it loose if it's rust welded.
7.3powersmoke
May 23, 2011 09:01 PM
bigcore1990
Nov 17, 2010 05:23 PM
crashxnxburn
May 5, 2007 02:37 AM
redskins13
Sep 9, 2006 06:07 PM
HIGDONII
Nov 21, 2005 10:12 PM
