She wont stay on to drive
Old Mar 24, 2025 | 03:10 AM
  #11
How did you get fuel pressure reading ?
Old Mar 24, 2025 | 07:24 AM
  #12
Inventor1949's Avatar
I plugged a pressure gage on the bleeder stem
Old Mar 24, 2025 | 11:01 AM
  #13
Please take a look under the back of your vehicle and see if you have a fuel pump driver module mounted on the chassis cross member.There should be one there.
They were known for corroding where contacting the cross member and that corrosion caused all kinds of problems.
Let us know if you see anything there, thanks
Is that it? Left is my backup beeper on the right I don't know
Old Mar 25, 2025 | 01:18 PM
  #14
Default Problem solved
After all the work I did I dint erase the code so the problem persisted the mechanic give me that little tip and walla she runs and drives grate.
So remember to erase the codes after each part you replace.
Old Mar 26, 2025 | 07:52 AM
  #15
This is an accepted procedure and we thought you were doing that.
Old Mar 26, 2025 | 01:22 PM
  #16
OldVanOwner's Avatar
What procedure? Am I the only one that didn't see the procedure posted?
Old Mar 27, 2025 | 07:19 AM
  #17
That step was never posted because , I have to say most, folks doing any diagnostic work know this and it was a mistake on my part thinking you already knew this.
Old Mar 27, 2025 | 11:52 AM
  #18
I'm curious... what is the procedure you're talking about? Can you just give us a "short version" so I'll know what it is? My '97 E150 5.4 is running rough and I'm going to be doing some diagnostic work in a few weeks.
Old Mar 27, 2025 | 07:24 PM
  #19
If you replace a part that was found to be defective or the cause of a problem, the vehicle computer doesn't know the part was replaced and will hold the code until that particular monitor is run again and passes after which it will automatically erase the code or depending on the vehicle year can be erased.
Old Mar 27, 2025 | 10:22 PM
  #20
Got it. Thanks Hanky.
Dodge
May 12, 2023 11:15 AM
azimuthny
Sep 20, 2022 03:39 PM
rtgiilbert
Jan 19, 2021 05:06 PM
vaidaslt
Dec 30, 2020 12:35 PM
TheGlassMaker
Apr 16, 2012 05:48 AM
