Shock absorbers
Old Nov 10, 2018 | 02:47 PM
Greg K's Avatar
Default Shock absorbers
2001 E350 shock absorbers need to be replaced and from what I can see it's going to be tough getting a wrench or socket on the top nut. Clearance is crap. My deep sockets are too deep, shallow sockets are too shallow. Am I going to have to grind a deep socket down? What tools has anyone successfully used and what size it the nut?
Old Nov 11, 2018 | 04:24 AM
The front shock nuts are easier to get at with the wheels removed Even then they can be a PIA. There are special tools that make the job a lot easier and it might be worth your while to check if your local auto supply store has them . One fits over the nut and the other allows you to hold the shaft and turn the nut.They are not that expensive . If you can't get in there any other way , I would definitely check them out.
Old Nov 19, 2018 | 11:26 AM
Greg K's Avatar
Yeah, I had the wheels off. I have offset box wrenches but they are 12 point and I don't want to risk stripping the nut, then I have a bigger problem. I think a special tool is my only hope.
tomrj
Jun 18, 2013 08:57 AM
topgeye
Sep 1, 2012 12:04 PM
Jason_8
Apr 27, 2009 06:28 AM
Darkhorse5.0
Jan 28, 2009 11:08 AM
treetopp87
Sep 21, 2006 10:18 PM
