shocks
Old Sep 13, 2006 | 06:29 PM
treetopp87's Avatar
Default shocks
i have a 99 ford ranger 2wd im tryin to figure out if there are any tricks to shock replacement all the way around looks like they bolt off and on and im just wonderin if there is anything i can possibly get snagged on?ps the shock is in the center of the coil spring.
Old Sep 13, 2006 | 07:43 PM
94 4x4 ranger's Avatar
Default RE: shocks
The back simply just unbolt.[hr]But the front's are a little harder.[hr]On the front the shock rod may want to spin when you are trying to dissasembell them you may want to grip this rod with vise grip's when taking off the top's of the front shock's.
Old Sep 14, 2006 | 06:06 PM
apollo's Avatar
Default RE: shocks
Since you helped me, I am going to return the favor. Check out the link:
http://www.ford-trucks.com/forums/50...-tutorial.html
Old Sep 21, 2006 | 10:18 PM
flamingitaur's Avatar
Default RE: shocks
The only problem that I ran into when replacing the shocks on my ranger were the bolts on the radius arms (front shocks). They were rusted on good, so when I tried to un-bolt them, the studs broke off. The fix was to torch out the old stud and stick a bolt all the way thru, securing it with a nut against the radius arm, and then sliding the shock over the bolt and securing it with another nut. The rear shocks were a piece of cake. Hope that made sense.
EFfalconsrule
Apr 10, 2013 05:26 AM
blakeoe
Apr 1, 2006 08:17 PM
bc in da hzhouse
Dec 5, 2005 01:58 PM
rrubalc
Dec 5, 2005 02:21 AM
PartsHookUp
Nov 29, 2005 08:22 PM
