Vacuum line ID help
Old Jan 2, 2018 | 01:06 PM
Dynamic21's Avatar
Default Vacuum line ID help
I have a 2004 Ford E-350 Super Duty. Some mice decided to make a home in the engine bay of my van this winter and I need some help ID'ing some of the tubes they ate through. I've attached a picture that shows the exact line they ate. It is the one of the bottom that has the red lines running through it and it bends at a 90 deg angle. What is the name of this line and any idea of where I could order a replacement? I can run new vacuum lines but it does seem I would need this connecting pieces because several smaller lines depend on this one vacuum inlet. Would a salvage yard be my best bet? Thanks in advance.
Old Jan 3, 2018 | 03:59 AM
I can't tell too much from the pix, but a problem with a plastic line is easily corrected by going to a auto supply store and getting a piece of fuel line or vacuum hose that will fit tightly over the broken line . Just separate the damaged line and use the hose to connect them together, usually a piece 2 inches long will easily contain the ends and solve the problem. They should have various size hoses to handle just about any size plastic line.
baconater357
Feb 9, 2017 03:11 PM
Rcw4324
Dec 14, 2016 10:18 AM
savren
Jan 14, 2013 12:22 AM
sardonicus
Oct 13, 2012 03:10 PM
skilletrx
Sep 24, 2008 10:01 AM
