Water leak out rear of block.
Old Mar 30, 2008 | 12:30 PM
FLAUSA's Avatar
Default Water leak out rear of block.
My 94 E250 300ci six has developed a water leak out the rear of the block between the block and the transmission bell housing. No water in the engine oil. I'd have to pull the transmission to see the leak. Does anyone know of a schematic online, or in a book, that would show the engines coolant reservoir? I'm seriously considering ditching the van as the problems are getting to be just too many and the transmission need overhaul anyways. AT about 13mpg it's getting a little expensive to drive it as well.
Old Mar 31, 2008 | 12:06 AM
Deep Sleep's Avatar
Default RE: Water leak out rear of block.
Sounds like a freeze plug in the back of the block. Easy to change once the tranny and flywheel/flex plate are removed.
Old Mar 31, 2008 | 05:58 PM
Gary2Wheels's Avatar
yep....as I recall ther's one behind the flywheel.
Old Apr 2, 2008 | 07:04 PM
FLAUSA's Avatar
That's what I was fearing. Oh well. Thanks for the insight
Old Apr 19, 2008 | 12:45 PM
goinstrong's Avatar
Shouldn't be afraid of the freeze plug. Just a cheap $5 job to pop in yourself. It's the trans. that would cost if it's too bad - of course they do have some cheaper overhaul kits for automatics as long as it doesn't have overdrive it's not beyond the average guy if you have a book for parts breakdown and torque specifications.
escaped-eric
Dec 23, 2012 01:33 PM
dirtycustom40
May 30, 2012 07:50 AM
krafty
Apr 4, 2009 11:35 AM
danny88
Sep 24, 2006 06:34 PM
mi97tbird
Nov 27, 2005 07:27 PM
