2015 AWD 3.5 tran leak
Well after a month of sitting the Edge is back on the road. my problem now is that there isn't a good way to keep track of the transmission fluid level. If it leaks into the PTU you wont know unless the PTU spews it out somewhere. Ford is suppose to extend the driveline warranty to 100.000 mi. for my trouble
"Ford is suppose to extend the driveline warranty to 100.000 mi. for my trouble"
edge150...Just curious, are they also extending the time frame and did they put this in writing or just give you a verbal warranty extension?
If you could post...What was the actual problem, cause and fix? That would help others who may come across the same/similar issue down the road.
lightsun
May 6, 2015 05:33 PM
