09 escape brake problem
Old Sep 1, 2018 | 08:15 PM
mgc1's Avatar
Default 09 escape brake problem
Brakes are mushy and pull (lunged) to the left. Replaced master cylinder, front calipers, rotors, and pads. Bled master cylinder, new calipers and flushed all lines. Bled from rr, lr, rf, & lf corners. Pedal goes to the floor, yet once its near the floor if pressed quick enough will actually kick in the abs - and does eventually stop after the lunge. But driving with this condition is not safe and an emergency stop is not possible. Could it be the hydraulic control unit? It seems the brake booster would not create uneven braking. I need expert analysis.
Thanks.
Old Sep 2, 2018 | 10:48 AM
I don't know about the expert part, but maybe some questions might shed some light on the problem..
Does the pedal still go to the floor if the engine is not running, if so, just what does it do if you pump the pedal a few times?
Did you bench bleed the master cyl before installing it?
If you replaced the calipers, do you have the caliper bleeders up on top?
What was the original problem?
rod525
Nov 1, 2014 07:52 AM
F150beater
Jul 2, 2012 02:00 PM
sublauxation
May 16, 2011 08:47 PM
blackharley
Mar 17, 2009 08:49 PM
MercuryMountaineer02
Apr 19, 2007 05:20 AM
