2004 Ford Escape V6 - Cracked Hose
Old Jan 22, 2022 | 05:31 PM
joeyg's Avatar
Default 2004 Ford Escape V6 - Cracked Hose
Hi all,
Can someone help identify this hose? I noticed it was cracked. Also, could it be the culprit as to why I'm getting an EVAP check engine light code?
And where can I get a replacement? Seems like something I could replace on my own. Any tricks to doing it?
Thanks!!
Old Jan 25, 2022 | 12:37 PM
scott.butler4's Avatar
I'm not sure if that's the EVAP canister output or return tube.
How dry rotted is the hose? Not a great idea but if its not dry rotted you may be able to cut it and install a male to male hose connector with clamps on both ends.
Old Jan 25, 2022 | 04:20 PM
raski's Avatar
You should be able to replace the entire hose with new hose, rated to withstand fuel vapor. The outer sheath is just a protective layer, there's nothing special with that hose.
Old Jan 25, 2022 | 06:39 PM
I realized that I said it was the wrong hose, the two I mentioned are the bottem two, I will check the workshop manual again tomorrow to see what that top hose is.
Old Jan 26, 2022 | 11:06 AM
joeyg's Avatar
Thank you all for your replies. Where can I get this type of hose? Should I go to the dealer? Any idea the name of it, or thickness if I want to look online? Thanks again
Old Jan 26, 2022 | 01:15 PM
Ok so that is the vacuum hose that goes from the intake manifold to the evap purge valve.
You could buy a new one from a dealer, buy one from a pull a part/junk yard vehicle, or just remove the hose and take it to the auto parts store to match it to another hose that will work and buy clamps to make sure it doesn't leak.
fevredream
Dec 16, 2021 11:28 PM
bcurry45
Aug 12, 2020 07:32 PM
LordCorpse
Jul 6, 2019 12:32 PM
Bethanyrhodes94
Dec 13, 2017 03:04 PM
bkancius
Aug 17, 2017 10:42 PM
