2005 escape l4
Old Jul 22, 2017 | 10:23 PM
Rob252's Avatar
Default 2005 escape l4
I just now replaced both lower control arms and both outer tie rod ends. And now the steering wheel is not straight anymore. Also there is a vibration. I know I need to get it aligned but can anyone help.?
Thank you.
Old Jul 23, 2017 | 05:20 AM
Was the vibration present before the work was done?
The person doing the alignment may be able to see the problem and help with a diagnosis and solution.
Old Jul 23, 2017 | 08:14 AM
Rob252's Avatar
Default Ford escape 2005
it was making sounds like something was loose before. I checked it and the tie rods were bad and the lower ball joints were bad. I also have changed the stabilizer links a while ago. The problem used to sound like the links were bad and that went away now i have another vibration that is there when i first push the gas.
Old Jul 23, 2017 | 09:00 AM
Sometimes a vibration can be from a cylinder misfire and also a cv joint . If it is caused by a driveline problem, the person doing the alignment can usually spot it.
goiou
May 16, 2009 10:40 AM
mnwhiterose
Apr 5, 2007 09:42 PM
mschwennes
Feb 18, 2007 01:42 PM
armygrunt2u
May 9, 2006 08:48 PM
oldschool1
North East
47
Jan 13, 2006 04:25 AM
