2005 Escape turn signal stays on
Old Mar 29, 2017 | 07:31 PM
rsmith05's Avatar
Default 2005 Escape turn signal stays on
I have a 2005 escape limited v6 that the right turn signal stays on all the time even when the key is off. I've checked all the fuses and they are good. The left turn signal works fine. I can't figure out what the problem is.
Old Mar 30, 2017 | 03:06 PM
You might try removing the fuses one at a time to see if any fuse other than signal lite circuit is feeding it or using it for a ground. Sometimes something from out in left field can be involved like wires rubbed through from rear wiper motor. Whatever is feeding it /using it does not require the key to be on.
Old Mar 30, 2017 | 06:38 PM
rsmith05's Avatar
I'll try that and see if that works, I've also been told it might be the Smart Junction Box. How do I test that?
Old Mar 31, 2017 | 11:48 AM
Usually you check and rule out all other possible causes before replacing the SJB. There is not too much testing you can do if you suspect that to be the source of the problem. Replacement is usually the only option. Have you considered getting a second opinion from another shop that can check and verify the actual cause before going the replacement route?
Old Mar 31, 2017 | 07:23 PM
rsmith05's Avatar
I thought the switch might be bad and unpluged that and the lights still stayed on, so that wasn't it.I'm going to try removing the fuses tomorrow and see if that works.
Old Apr 11, 2017 | 08:38 AM
rsmith05's Avatar
It was the smart junction box
Glowbug
Jan 28, 2022 12:43 PM
58bowty
Jun 4, 2014 07:32 AM
mgan9311
Jan 5, 2012 07:00 PM
Checkedwood
Oct 16, 2009 02:36 PM
kenny2469
Dec 6, 2006 04:14 PM
