2007 Escape Trans Fluid Change Question
Old Nov 12, 2018 | 11:35 AM
turnstyle's Avatar
Question 2007 Escape Trans Fluid Change Question
Hi, thanks for reading:
I have on 07 V6 auto with 170K miles. Did a drain and fill myself. Before draining, level was at bottom of cross hairs when hot. I drained just under one gallon (4 quartz). After draining I added new fluid and ended up adding 4 quartz Mercon V (kept checking level with engine running). Drove for 20 minutes and checked again...level was at top of cross hairs. This morning I wanted to check it again when cold and the level is one inch above the ball! How is this possible? Do I need to drain some of it off...or maybe try pumping it out?
note: car was always level when I checked fluid, and it drove and shifted fine on test drive.
Old Nov 12, 2018 | 01:04 PM
Welcome to the site
Sometimes transmission will have torque converter drain back after setting for some time.
Since the brunt of the converter fluid is above pan levels, if the converter bleeds off a bit, the level in the Trans raises. Not terrible uncommon, more so in higher mileage units...
If fact,, in more moderate cases, after setting periods of time you may experience some delay in applications in D/R of a few seconds or so as fluid is replaced.. Once filled, normal functions..
The issue was probably there before your service, just not noticed.
The fill check heated should be correct/ed
Old Nov 12, 2018 | 01:34 PM
turnstyle's Avatar
OK, that makes sense. Thanks for the explanation! I just drove it again for 10 minutes and level is middle of cross hairs.
Old Nov 12, 2018 | 03:25 PM
When you mention checking it cold, is that a static check, or running in Park?
If converter drain back, It’s generally a check valve bleed at the front pump, but isn’t a concern in most cases..
Old Nov 12, 2018 | 06:39 PM
turnstyle's Avatar
The cold check was static and after it had sat overnight. Glad to hear it's not too big of an issue but I'll keep an eye on it for awhile...and only check it when it's hot. Thanks again!
Bubba
Feb 11, 2019 02:52 PM
Sean1111
Oct 24, 2018 06:28 PM
oakshade_racer
Jun 26, 2013 04:37 AM
ReyF-550
Mar 24, 2012 10:10 PM
Den
Aug 16, 2010 09:02 AM
