2009 Escape 5speed manual trans fluid alternatives
Old Jul 18, 2022 | 08:34 PM
vipe46's Avatar
Default 2009 Escape 5speed manual trans fluid alternatives
Hello all, I am going to be doing a trans fluid change on my wife's Escape and wanted to know if there are any recommendations for alternatives to the Motorcraft GL4 75w-90 fluid, which is about $30 bucks a bottle at local dealer. Not finding much that are GL4 compatible at the local stores or are lacking details as to whether to use in GL4.
Thanks!
Old Jul 19, 2022 | 02:58 AM
raski's Avatar
Stick with a GL-4 as recommended which is safe for "yellow" (brass) found in the synchros.The sulfur found in GL-5 lubricants which is for differentials, can do the damage to those parts in your MT.. An alternative would be a Redline oil which is still costly but much cheaper than a Ford product. You are only going to change out the gear oil once or twice in the life of the vehicle, do it right and don't skimp.
https://www.redlineoil.com/mt-90-75w90-gl-4-gear-oil
Old Jul 19, 2022 | 03:56 AM
vipe46's Avatar
Yeah I believe you're correct. After doing more research on some other GL4 oils Motorcraft seems the way to go.
thanks
kevgray
Sep 19, 2021 06:37 PM
Jeff N
Jul 23, 2021 12:58 PM
ViMatson
Jul 24, 2013 09:02 AM
pickerbush
Jul 14, 2009 06:54 AM
81F150
Mar 20, 2007 10:17 PM
