2009 Escape Fuel Tank Replacement
Old Nov 13, 2022 | 12:14 PM
katman96's Avatar
Default 2009 Escape Fuel Tank Replacement
Hi , newbie to this forum. Im about to replace the fuel tank in my 09 Escape 3.0, just looking quick at it. Does anyone have a procedure for this?
Will I need to drop the driveshaft?
Thanks in advance
Old Nov 14, 2022 | 07:45 AM
Not knowing what kind of equip and facilities you have to work with, if the tank is just about empty ,it won't be too heavy.
If it has fuel in it , anything you can do to make it lighter will also make the job easier.
Something you should keep in mind, contact with today's gasoline is not good to get on your skin. so protect your hands.
Also don't use any kind of electrical lighting to see what you are doing , BECAUSE,,,,,,,,, if gasoline comes in contact with a hot droplight bulb, JUST NOT GOOD !
If the driveshaft appears to be in the way to drop the tank, just mark the position where it is presently bolted so it goes back to the same position to prevent possible vibration problems and disconnect one end and just position it out of the way. Be aware you will need the special tool to disconnect the fuel lines and filter.
Procede slowly and be safe so you can enjoy the fruits of your labor.
Old Nov 14, 2022 | 08:58 AM
katman96's Avatar
Thanks Hanky, all good information....
2009FordEscape
Apr 21, 2021 06:09 PM
TheRandis
Jul 1, 2020 09:14 PM
euebelhoer
Dec 8, 2015 02:33 PM
etradebaby43
Mar 20, 2013 12:12 PM
needlepointer
Oct 21, 2010 04:56 PM
