2011 2.5l 'misfire' > Update
Old Apr 1, 2022 | 10:02 PM
whilst's Avatar
Thumbs up 2011 2.5l 'misfire' > Update
Hi all, >Hanky.
Elusive misfire solved.
Sunken exhaust valve/seat # 2 cylinder.
Valve is kind of mis-shaped, very thin edged on one side -corroded!
Saw similar on a 'youtube vid'. warped valve.
Now, since these are 'solid lifter/shim type cams/valves; there is no compensation for wear.
Therefore,valve was getting less and less clearance > opening slightly when it should be closed.
Hence misfire even when 'static' compression test showed minimal difference!!!
So, bought junkyard Fusion engine,'allegedly' 89K for $650 w/ $50 core charge!?
Installed in daughter's car and sent her on way to Austin. 1500 miles and well,so far.
Fingers crossed. HTH.
Old Apr 2, 2022 | 06:52 AM
Thank You for the update.
Always good to hear when things go well.
whilst
Feb 17, 2022 08:42 AM
Tony Torque
Mar 21, 2018 01:56 PM
deathrider2
Mar 21, 2013 07:23 PM
carter1984
Mar 2, 2011 06:11 PM
summerson1
Jul 25, 2010 06:48 AM
