2012 Escape will not start
Old Feb 21, 2022 | 07:53 PM
eagle592's Avatar
Default 2012 Escape will not start
Parked the vehicle then the next morning it would not start. The Theft light lit up. got the keys recoded and that went away. Still not turning over much less starting.
No fuses blown,
Replaced the starter per Code review. Still not turning over.
Old Feb 21, 2022 | 11:22 PM
scott.butler4's Avatar
Specify what fault code you found.
Also what engine you've got.
Old Feb 24, 2022 | 03:44 PM
eagle592's Avatar
Good afternoon Mr. Butler,
Thank you for asking for additional information.
As for the Fault Code?
The tech (That Key Dude) that recoded the ignition keys had what appeared to be a "Shop Grade" Code Reader.
He used it to try and determine why the engine would not start.
According to him, the code read: Bad Starter
He did not (nor did I ask for) provide the Code Number.
He was generous to me since the key/s did not start the engine, he refused to accept payment for his service call; NOTING his Guarantee to deliver results or NO COST.
FYI, I sent him an Omaha Steak package anyway and his "thank you" was very gracious to say the least.
Anyway as I noted previously; I replaced the starter EVEN THOUGH the original starter performed per specifications during a Bench Test at the local AdvanceAuto.
Meanwhile I can confirm that this 2012 Escape has the 2.5L (inline engine).
While reading some of the other forum responses I saw one (1) that suggested "pushing" the key "inward" while turning the key.
Hoped for the best, BUT NO JOY.
This issue is a true mystery, especially since it "just popped up" out of the Blue with no hint of trouble.
Look forward to your further insight.
Old Feb 24, 2022 | 07:04 PM
You can check for voltage at the large alternator and large starter cables, when the key is on.
If the fault code is still present you need to find out what the actual fault code is, for example P0301-24.
pappataz
Mar 19, 2024 06:54 PM
Wolfman51505150
Nov 19, 2021 05:14 PM
laislabonita
Oct 15, 2021 04:47 PM
hotrod308
Aug 13, 2019 05:46 PM
wmanimal
Apr 13, 2013 07:26 AM
