2013 Ford Escape with 1.6 engine
Old Jan 22, 2019 | 11:09 AM
lindajordanfoss's Avatar
Default 2013 Ford Escape with 1.6 engine
I have a 2013 Ford Escape with a 1.6 engine with the echoboost and it has been loosing coolant and been to the garage and can't find out where it is going suspect the motor, you can smell it when you shut it off but lo anti freeze lying on the ground anywhere or none that you can see at all when you check under the hood, so frustrating had it to garage and spent bucks on it and no answers. I looked and said there was a recall on these but I called and my VIN number they checked and sad no not on that one, I am here to tell you I think they missed this one cause it is going somewhere, any answers would be appreciated, thanks.
Old Jan 25, 2022 | 01:06 PM
Shospb46's Avatar
Default Same problem!
I have the same problem. Compression test didn't find anything. My mechanic believes its the water pump and told me I'm better off at the dealer (he hates these cars). My research also showed the Coolant Bypass Valve "C" my need replaced. Let me know if you ever figured it out. Thanks!
Stephv1
Aug 11, 2018 12:42 PM
NikjMiles
Jul 20, 2014 11:07 PM
carsnewstoday
Apr 28, 2014 07:41 PM
ruxford
Apr 1, 2014 12:53 PM
bb97007
Aug 19, 2012 08:56 PM
