2014 ford escape false overheat after engine replacement
Old Apr 11, 2022 | 08:36 PM
Mightykay19's Avatar
Default 2014 ford escape false overheat after engine replacement
Hello, I own a 2014 Ford Escape 1.6 L- FWD, My engine failed due to being out of time. I order a used engine with 94000 miles on it, the engine was in working condition before being removed, and I had it installed by a mechanic at a shop. However, within 1 minute of the car being started, there is a notification on the screen that read: High Engine Temperature Stop Safely. Upon scanning the following code came up P1299 Cylinder Head Over-temperature Protection Active. The coolant level sensor, the coolant temp sensor, and the Cylinder Head Over-temperature Protection sensor were replaced. The shop also reset the PCM however the issue is still there. The engine does not overheat while it is running from the data received on the tech computer. So far the tech at the shop told me the issue is electric and he will continue to work on it. My car does not have a remote start and is out of warranty. I would appreciate any opinions on resolving this issue.
Mightykay19
Apr 14, 2022 11:26 AM
makuloco2000
Jul 13, 2014 10:50 AM
makuloco2000
Jun 16, 2014 10:39 PM
BIG DADDY RACING
Dec 16, 2009 06:23 PM
cctxfish
Sep 16, 2005 04:51 AM
