2015 escape doors locking
Old Feb 18, 2020 | 11:14 AM
Jason Schalla's Avatar
Default 2015 escape doors locking
Everytime the drivers side door handle is opened (either from the inside or the outside) all the doors lock. It doesnt happen with any other door handle. We have replaced the batteries in our fobs thinking that's what it could have been but the problem is still happening. It doesnt matter if the keys are in the car or are away from the vehicle. I have also noticed that if I unlock it and get in right away that both turn signals blink twice on the dash. The vehicle has no issue starting and we have had no other signs of it being the battery. Any advice would be great
Old Feb 19, 2020 | 06:19 PM
The visual response from the remote keyless system sounds like it is misbehaving. The object is to determine why. I would suspect there is something going on with that system and either a driver's door module or body control module is involved here
A good quality and capable scan tool might be able to check the system and suggest the cause.
Once in a while Gremlins get loose in the system and a forced reset helps get rid of them/ A forced reset consists of removing the negative battery cable and holding it against the positive cable allowing the internal capacitors to discharge and the Gremlins to escape. This ,however , creates another problem where memory items are also erased from the vehicle's computer, like radio stations, memory seats,mirrors, shifting scheduling and some others. Here again , a good scan tool and experienced tech would have better luck pinning down the problem.
Lindseyf
Apr 15, 2024 05:41 PM
Wiz70
Nov 14, 2018 10:09 AM
bruce7966
Aug 19, 2016 10:50 AM
gatorvette
Dec 31, 2013 02:55 PM
jase00
Dec 8, 2012 10:37 AM
