2015 Escape SE Light, Turns and Wiper Problems !!!
Old Aug 30, 2016 | 04:33 PM
1812XL's Avatar
Default 2015 Escape SE Light, Turns and Wiper Problems !!!
Hi, I got Ford Escape SE 2015 with front end collision. I had to replace some front parts, and after all was fixed now I have issues that:
1. My Wipers dont work properly, they get into collision and get stuck;
2. My Left low/high beat light dont work properly - when on low beam, the bulb is very dark compare to the right side, and when I turn on high beam, the left side goes away completely.
3. The turn signals sometimes work OK, sometimes click quicker than suppose to be, like on the bulbs is Out, when its Not.
Also, my car, doesn't speed up as suppose to. It has 2.0 Eco engine, but it is soooo slow when I drive it.
ANY ADVICE ????????????
Old Aug 31, 2016 | 05:35 PM
I don't know about advice, but you might want to check that all the ground wires are connected for the left front of the vehicle and for that matter the ground wires that ground the sheet metal and body to the battery negative post. From what you describe it sounds like one or more are either not making a good connection or may be missing entirely.
Old Sep 1, 2016 | 10:39 AM
1812XL's Avatar
It really is sound like the ground is missing somewhere. I'll try to check all the wire harness and see, make sure it doesn't cut anywhere or missing ground.
Thank you so much for your advice !!!
ShibbyX13
Dec 3, 2015 03:22 PM
farsee
May 18, 2015 11:25 AM
kalenkerby
Mar 27, 2014 03:58 PM
mommabeans
May 2, 2013 08:53 AM
tcrate
Sep 9, 2011 07:11 PM
