2017 rear hatch won't open
Old Oct 20, 2023 | 04:24 PM
Andymon's Avatar
Default 2017 rear hatch won't open
I replaced the rear hatch actuator in my 2017 Escape. The remote closed the hatch but now it won't open. Neither the fob, the hatch button or the switch on the dash will open the hatch. I can hear a click when I try but that's it. No manual release either. How can I get the hatch open? I have a new OEM Ford actuator.
Old Oct 21, 2023 | 07:18 AM
If there is excess pressure on the latch assy it cannot release..
What you might try is to push on the entire door and see if the latch will release.
You have to be pushing on the door at the same time as trying to get the latch to work.
Old Oct 21, 2023 | 10:57 AM
Andymon's Avatar
Tried that as well as pulling on the rear door. The actuator just clicks or makes a grinding sound like the gears can't get a grip to release. Taking it to the dealer on Monday. I have a new OEM actuator I'll give them.
Old May 28, 2024 | 05:15 PM
cgreen's Avatar
I just ran into the same problem, did you find out what the issue was?
Old May 29, 2024 | 10:49 AM
Andymon's Avatar
I ended up having the dealer fix it. Unfortunately they wouldn't use the OEM part I got from another dealer in another state.even though it was about 200 bicks less. Jerks. They said they could only use the parts they provided. Anyway, it's fixed with a 2 year parts and labor warranty. Why Ford didn't make a manual release is beyond me. Seems like a real safety issue.
Old May 30, 2024 | 08:50 AM
cgreen's Avatar
That sucks! Well not to pour salt on the wound, but I thought I would put this here for the next guy. I disconnected the battery for 30 seconds and then reconnected and my trunk started working. This was with a new actuator I bought off Harfington for like 85 bucks. I was so close to breaking it apart to put the old one back on. Pulling the fuse didn't work as a reset, so don't even bother unless you think it's blown.
Old Jun 14, 2024 | 03:33 PM
wan=nders's Avatar
THANKS! This helped me a ton (and I pulled fuse 65 and also figured out how to manually release the latch). It seems that the body control module detects the open circuit when replacing the latch, then disables the latch until the next power cycle. Safety feature? Anyway, this isn't mentioned in any of the online videos that I saw.
SmokyTech
Oct 25, 2021 08:57 PM
kmpres@optonline.net
Jul 26, 2021 07:41 AM
Bits
May 13, 2018 05:57 PM
EmmalouK
Jul 7, 2012 11:38 AM
EmmalouK
Jul 7, 2012 04:29 AM
