2024 Escape Brake Light Switch
Old Oct 4, 2024 | 08:57 PM
New Ford Owner's Avatar
Default 2024 Escape Brake Light Switch
I have a 2024 Ford Escape and I'm trying to wire in a trailer brake controller I already have. I need to connect to the brake wire coming from the down side of the brake switch.
Looking under the dash I don't find the expected brake switch in the mounting bracket. There is a braket with the expected mountung hole but no switch.
I can't seem to identify a brake switch attached to the brake pedal as in every Ford I've worked on before.
Any idea what I'm looking for, I'm stumped.
Old Oct 6, 2024 | 05:11 PM
Not sure if they use a manual or hydraulic stop light sw.
You might trace the wire coming from the stoplights and use that wire.providing the vehicle has separate signal and stoplights..
Otherwise, you may need to look further where the stoplight signal comes to the signal light sw..
Old Oct 6, 2024 | 05:19 PM
It is mechanically operated by the brake pedal. Just look for where the pedal pushes in a plunger on a plastic sw assy when the pedal comes up.
Old Oct 7, 2024 | 11:06 PM
This is the switch your talking about, looks like the one here. There is a bracket where you would expect this to mount but there is nothing there, no switch, no wiring. I've changed many like this before.
There is nothing mounted with the brake pedal, just the pedal and pivot point and linkage to the master cylinder.
I can only assume that they chenaged to a hydraulic switch which would be mounted with the master cylinder. Can't locate on their either. Guess I'll have to take it to an RV installer to get it done..
Joe Reeves
May 1, 2014 04:12 PM
zlingelbach
Dec 16, 2013 12:45 PM
billcath3517
Dec 12, 2008 06:40 PM
rlevy64614
Sep 25, 2008 09:13 PM
clark53426
Mar 6, 2008 08:23 PM
