Abs bleed
Old Sep 9, 2023 | 01:23 PM
Ronald lancour's Avatar
Default Abs bleed
Hi there I'm a little confused I purchased the auto MK 808 Z-bt and I'm trying to do the auto bleed on a 2004 Ford Escape front wheel drive 3 l and all the computer does dude hold me hold the pedal down hit okay Light It Up hit okay and then it activates the motor for the rear I would think you're supposed to open bleeders but I am not really sure I was wondering if anybody had any input hopefully I described what I'm trying to basically I'm confused thank you for your time in advance I am new to this forum thank you again
Old Sep 9, 2023 | 04:20 PM
If you have a pressure bleeder to use , you can utilize the scan tool to open the valves in the ABS system and open the bleeders to allow trapped air to exit.
You can bleed them with some one holding pressure on the hydraulic system and you opening the bleeders and using the scan tool to hold the valves in the system open.allowing the trapped air to exit..
Lone Eagle
Aug 16, 2009 04:20 PM
hefty
Mar 17, 2009 09:22 PM
myjeep
Sep 16, 2008 06:53 AM
Hutch64
May 31, 2007 09:21 PM
Dis@ster07
Oct 27, 2006 09:10 PM
