Adjusting Rack and Pinion Slop 2003 Escape
Old Jun 10, 2019 | 10:27 PM
tinkering's Avatar
Question Adjusting Rack and Pinion Slop 2003 Escape
2003 Ford Escape
Do I need to remove the R&P unit from the vehicle to make any adjustments to clear up the slack in the R&P, if there are adjustments available? It looks Awfully tight up/down in there?
Thanks
Old Jun 11, 2019 | 03:35 AM
Can you see where the slop is coming from? Most of the time it is from the inner tie rod ends which can be replaced ,on car , with special tools , after which an alignment is required..
Old Jun 11, 2019 | 07:20 PM
tinkering's Avatar
No, I can't see in there especially with the flex boot over the joint. It doesn't sound like the inner tie rod end. When I push and pull the wheel from side to side, I hear a clacking almost like a bouncing from behind the fender just forward of the door. This is exactly the same on both the drivers and passenger's sides.
When someone holds the steering wheel still though, I cannot generate that sound at all. It's like there is slop instead of preload between the rack & pinion gear... but it doesn't make sense to me; it should make that noise with the steering wheel held still too, shouldn't it!???
I have to double check that I flexed the wheel on both sides while steadying the steering wheel; That could make a difference if it has noise on one side and not the other.
bradleyheathhays
May 22, 2020 04:48 AM
Marc Roffman
Sep 26, 2016 02:01 PM
Luis0227
Feb 19, 2016 12:07 PM
Harry18
Sep 11, 2006 03:09 PM
aagostinelli
Mar 19, 2006 02:09 PM
