Am I having a transmission issue?? I can push the car while its in park
Old Oct 6, 2017 | 12:58 PM
Dee M. Lewis's Avatar
Default Am I having a transmission issue?? I can push the car while its in park
I have a 2005 Escape with the 4 cylinder AWD and I'm not sure if I'm having a transmission problem or an issue with the axle or U joint. The vehicle makes a grinding noise when shifting from park to reverse and sounds even worse when shifted back to park. The car does not move under its own power but it can be pushed even when its in park.
Old Oct 6, 2017 | 10:30 PM
cngizbleevng's Avatar
Did it happen suddenly or gradually? How many miles on the Escape?
Old Oct 7, 2017 | 11:39 AM
Maybe a little background might help here,
In the auto trans there is a parking pawl that a spring places into formed knotches in the output shaft piece when park position is selected. In vehicles without an AWD or transfer case the output shaft of the trans now prevents the differential from moving and also the wheels.
If for some internal reason there is a disconnect within the AWD or transfer case , the wheels are not held from moving. When the output shaft of the trans is not held stationary and you attempt to place the moving internal parts of the trans into park you get that ratcheting sound you are hearing and this can break the pawl in some cases . I would think there is a problem with the AWD system in your vehicle and unfortunately this can get expensive to repair. There are electrical as well as mechanical parts involved and try to have someone that is familiar with the system check it out.
Kathleen Covill
Feb 16, 2016 10:49 AM
lexukc
Mar 19, 2013 05:15 PM
b0mbtrack
Apr 8, 2011 05:51 PM
sechlerk
Mar 16, 2011 05:06 AM
TNGoober
Dec 23, 2009 03:29 PM
