Car cranks too long before starting
Old Apr 6, 2018 | 10:19 PM
Lesr's Avatar
Smile Car cranks too long before starting
2011 Ford Escape Limited 3.0L V6
1. If car is left parked (off) for a couple of hours or more, it cranks for 4 to 8 seconds before the engine turns on.
Then it runs great.
2. The car starts normally If the ignition key is turn to ON for 10 sec, then to OFF, then again to ON for 10 sec,
ALWAYS.
3. The car also starts normally if it is off only a few minutes.
I suspect that my fuel pressure goes low when leaving the car off. The longer it remains off, the longer it cranks.
I found a fuel pressure sensor, but I have not found a fuel regulator (is there one?). can the sensor cause this?
Any suggestions will be deeply appreciated. Thank y'all
Old Apr 7, 2018 | 04:03 AM
Could be either of these,
defective check valve in line from pump to engine,
defective fuel press reg
Both are part of fuel pump module in fuel tank.
Old Apr 15, 2018 | 04:18 PM
Lesr's Avatar
Thanks for your reply hank,
After two weeks of turning key to ON 10 seconds before starting, the car is staring just find now, without delay. Did I just reprogram the initial throttle position in the PCM????
Any way, car has 87k miles, so will replace original spark plugs, check battery, new filters, etc. oh yes, just added fuel cleaner to the tank.
i just do not like problems that magically disappear.
btw, the car is well maintained. Throttle is clean, no vacuum leaks, etc.
thanks to all. Great forum
Old Apr 15, 2018 | 07:05 PM
You never know when you're "gonna get lucky."
I am inclined to agree with your reasoning about problems that magically disappear.
If a check valve was sticking and you managed to get it to work, however you did, let's hope it works correctly from here on in.
It's always great to hear a problem corrected itself, thanks for the update !
Justin Rider
Jun 10, 2017 09:52 AM
Ctwngrl07
Jun 19, 2012 06:16 PM
archie
Apr 8, 2010 02:14 AM
jeffandteneka
Feb 16, 2007 09:58 AM
johtwe
Jan 24, 2007 01:50 AM
