Drivers side rear door lock 2005 XLT
Old Mar 27, 2021 | 09:29 AM
Metalicmike's Avatar
Default Drivers side rear door lock 2005 XLT
All the wiring diagrams Ive seen so far show four wires, 2 for lock motor and 2 for door ajar, Do's any one know what the 5th red wire is for, the mechanism is a 5L84 78264A01
Old Mar 28, 2021 | 09:56 AM
scott.butler4's Avatar
Wiring diagram only have four wires, I would recommend posting a picture of the wiring you have in your door.
Old Mar 28, 2021 | 02:43 PM
Thanks for the reply. The outer pair supply the latch motor, 2nd and 3rd from left are door ajar. 2nd from right is a mystery.
Old Mar 30, 2021 | 12:56 PM
Scott, could you please post page 110-2, thanks.
Old Mar 30, 2021 | 05:26 PM
Posted an image but its disappeared, The plug has the four wires shown as your Diagram but there's a red on pin 4
Old Mar 31, 2021 | 07:05 PM
Here is 110-2.
@Metalicmike The moderator has to approve you for posting pictures.
Old Apr 1, 2021 | 06:35 AM
Thank You.
Old Apr 1, 2021 | 08:32 AM
M Mike,
Can we inquire what was the reason you got involved in the driver's side door lock area ?
There must have been some problem, or wasn't there?
Old Apr 1, 2021 | 11:23 AM
Central locking was acting a bit weird, Drivers door and trunk lock opened and all locks but the drivers side rear would lock. I suspect the lock motor is blown as its open circuit but not knowing the function of this mysterious red wire, coupled with this lock being more expensive makes me unsure. Finally its probably the only Escape/Maverick on the Island so I have to order parts from the States, its a great car, had an xls in the UK and hoping this last me out. :-)
Old Apr 1, 2021 | 02:27 PM
Were you able to supply power directly to the door lock /unlock motor assy to verify the mechanism itself did not respond?
If it does, then you would be reasonably sure the problem lies elsewhere, what do you think?
