Fan only works on highest setting
Old May 27, 2019 | 05:08 PM
cngizbleevng's Avatar
Default Fan only works on highest setting
Was driving my son's escape the other day and noticed the fan only blows when the setting is on 4. No other setting produces airflow at all.
Any suggestions as to why this would occur?
Old May 27, 2019 | 06:18 PM
Hi fan speed is usually controlled by a separate relay because of the hi current required.
All other speeds usually go through a resistor that is generally mounted near the fan motor usually held by 2 small screws, easy to replace.
Most auto supply stores have those ,Blower Motor Resistors and not expensive..
Old May 27, 2019 | 06:30 PM
Thanks so much, hanky. That makes sense.
Old Jun 2, 2019 | 04:44 PM
Hanky, you hit the bullseye. Replaced the resistor yesterday--took all of 15 minutes. Now my son has his fan back for a long trip in a couple weeks.
brfan1
May 25, 2017 09:39 AM
NDL
Oct 15, 2014 02:05 PM
Des
May 15, 2010 12:23 PM
law2rew
Nov 29, 2007 09:31 AM
bill1714
Jul 17, 2006 09:50 PM
